Old 07-28-2017, 08:55 AM   #1
Biscayne
Biscayne's Avatar
Liked 2 Times in 2 Posts
Default Re: 459 Chevy Intake
Scott, Probably not hearing anything because nobody here has first hand knowledge .
There might be one or two 300 hp Stockers out there , but that doesn't help you much with a 383.
All I know is it's worth a bunch over a real 283 intake.
Does the carb have to be stone stock, or NHRA Stock?
Mark, thanks. It can be an NHRA Stock carb. I was gonna try to run a 409 400 hp AFB carb as it's bigger then the 327 carb
Scott Chalk 1226 I/SA
Biscayne is offline   Reply With Quote
Old 07-28-2017, 04:38 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
Why not a 780 or 850 cfm Holley? Both are carbs listed for NHRA Stock engines.
Old 07-29-2017, 01:56 PM   #3
Biscayne
Biscayne's Avatar
It would be for a 1962 or 1963 327 300h.p. combo. Can't run a Holley. Has to be an AFB with the 459 intake.
Old 07-29-2017, 04:17 PM   #4
Paul Precht
Paul Precht's Avatar
Liked 307 Times in 116 Posts
Run a large AFB like the one that came on a 67 440 GTX, it has the small airhorn so it will look stock and yet flow at least 100 CFM more than a 409 AFB.
Old 07-30-2017, 09:40 PM   #5
Biscayne
Biscayne's Avatar
Thanks Paul. Have a list number for that carb. Thanks.
Scott
