#21 |
Liked 325 Times in 50 Posts
I also have a complete Moser Dana 60 w/5.13 pro gear axle to axle. Call for more info.
Jeff Teuton 4022 STK |
#22 |
Liked 53 Times in 38 Posts
All this bad vibe has made me change direction, going with Dana instead. Always heard the 8-3/4 was more efficient.
#23 | |
Liked 138 Times in 51 Posts
1) GM 12 bolt 2) Dana 60 3) Chrysler 8 3/4 4) Ford 9" I believe it said that the biggest factor is the placement of the pinion in relationship to the ring gear. The higher the pinion (closer to center), the more efficient it is. The 9" has the additional disadvantage of an extra pinion bearing. I don't recall what others were tested. Somebody makes/made a 12 bolt style center section for 9" housings. Was it Jim Kinnett that had a 12 bolt or a Chrysler 9 1/4 rear in his SS/AA Cuda?
LOCOMOTION Racing |
#24 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
#25 | |
Liked 320 Times in 102 Posts
Strange still manufactures an aluminum 12 bolt drop out center section that fits into a 9" Ford housing........ I wonder if that will pass tech (HA HA) for a GM Stock Eliminator car????? Just sayin'
#26 | |
Liked 780 Times in 194 Posts
I remember that same article, but have since learned from other sources who have done serious experimentation that the Dana 60 is more efficient than the 12 bolt.
#27 | |
Liked 1,596 Times in 583 Posts
#28 | |
The Strange 12-Bolt, 9" drop out has weight limitations on its use. It's designed for very lightweight cars, dragsters and roadsters. |
#29 |
#30 | |
Liked 6 Times in 5 Posts
