Old 06-11-2017, 08:58 AM   #51
carl hinkson
Liked 18 Times in 10 Posts
Default Re: Hardblock?
Originally Posted by David Lee View Post
that has nothing to do with the other engines that do not have replacement blocks and you admitted
I build a lot of engines with OEM blocks and no problems to date.
so i do not see what your problem is. Either we need to some how get blocks that do not exist or use the blocks we have.
I am planning on sleeving a 318 block and getting it bored to 273 specs.
And your personal attacks are not doing a thing.
Sounds like your an engine assembler not an engine builder that does his own work and has the right equipment to the job.
Big difference between you and I if that's the case.
carl hinkson is offline   Reply With Quote
Old 06-11-2017, 02:37 PM   #52
David Lee
Liked 346 Times in 126 Posts
Yes there is a big difference between us. And it has nothing to do with racing. And the person advising me is quite adept at doing his own building and machining, and build some very competitive engines. I am done with your childish antics.
Old 06-11-2017, 05:06 PM   #53
Wink Re: Hardblock?
My rule of thumb if you have to fill the block your using the wrong block,
Cylinders change during heat cycles and and never come back to the original machined size.
Carl , I think David's point should be well taken.
You're not using the wrong block, if there is no replacement available.
The last block that I filled , did not have a replacement.
After several no. 1 qualifiers and a Nat'l record, it never dawned on me that I was using the wrong block.
Perhaps you should have qualified that statement at the outset. Just sayin' .
Old 06-11-2017, 05:26 PM   #54
James L Miller
Liked 25 Times in 16 Posts
Mark, thank you for standing up for those of us that want to run an odd-ball (Non-Chevy) combo. I didn't see a Mopar 273 on Carl's website.
http://hinksonautomotive-cncblocks.com/products/
Mopar 2 Ya!
Old 06-11-2017, 08:22 PM   #55
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Hardblock?
On our 267 chevy we took a 305 block and sleeved it down to 3.50. Didn't fill it and had reasonably thick cylinder walls. Still leaks 2 to 4%after 60 runs. Aftermarket block is the best way to go but we ended up with a decent block for half the price of aftermarket.
Bill Bogues 4696 STK
Bill Bogues is online now   Reply With Quote
Old 06-11-2017, 08:52 PM   #56
David Lee
Do you think adding hardblock would have helped the leakdown?
Old 06-11-2017, 11:37 PM   #57
carl hinkson
From what I have seen with sleeving blocks and more so all eight sleeves put a lot of unwanted stress in the block and after a few heat cycle the cylinders don't stay round.
Old 06-11-2017, 11:39 PM   #58
carl hinkson
I have no interest in CNC machining Mopar blocks not much call over the years so its not worth tooling up for a block you might do once a year
