#11 |
Liked 273 Times in 142 Posts
Out of curiosity, is the car a Hardtop or a Sedan? My Grandfather had a brand new '65 383/330 Sedan. It ran C/SA then!
I agree with Mark also, if you think the 516's and the carb are detrimental to the combo, you need to rethink your plans. Plan on spending most of your money on the heads. It's not going to be a "dime rocket" for sure, but it also shouldn't break the bank to build it and be somewhat competitive. |
#12 |
Liked 25 Times in 16 Posts
I would think the bowls in the Edelbrock exhaust ports would need welded up and smaller seats put in for the 1.60" exhaust valves. I guess since they allowed "any valve job", welding the area under the seat is OK and then remachined? Or do you have to leave a big step under the seat since welding isn't legal on a Stocker head? Is the NHRA legal head coming with valve seats installed? I think they were, not sure if they still are.
Mopar 2 Ya! |
#13 |
Liked 55 Times in 4 Posts
The 915 heads are better than the 516 heads. Those 915 heads are from 1967, where two versions were produced by Mopar, one with a 1.60 exhaust valve, the other with a 1.74 exhaust valve. Of course, you have to use the version with the 1.60 exhaust valve. Dean Oliver does a great job setting up the AFB for stock. We used CP pistons, which were flawless. If you can afford it, use the legal aftermarket rods specified by NHRA.
A few years ago, I wrote a Car Tech book, with huge help from Jim Hale, on building a 383 for Stock for my someday soon '66 Coronet stocker. It might help you decide if you want to run a 383. Arvid Svendsen |
#14 | |
Liked 53 Times in 38 Posts
#15 |
http://www.edelbrock.com/automotive/...approved.shtml
http://www.edelbrock.com/automotive/...r-rpm-bb.shtml "Combustion chamber volume: 75cc / 84cc / 88cc Intake runner volume: 210cc Exhaust runner volume: 70cc Intake valve diameter: 2.140" Exhaust valve diameter: 1.81" Valve stem diameter: 11/32" " I think someone said they weren't cutting the seats, so that would help with the standard 2.08"/1.74" valves. Then you need to ream the guides for 3/8" stems.
Mopar 2 Ya! |
#16 | |
#17 | |
Liked 346 Times in 126 Posts
get a hold of shane studley on facebook. |
#18 | |
Liked 307 Times in 116 Posts
#19 | |
Liked 279 Times in 68 Posts
Greg Hill 4171 STK |
