#21 |
Liked 31 Times in 10 Posts
You need an ultra bell if you want the cracking issue to go away for good. Even with the brace the factory bell will still crack.
Michael Brand II 505B - F/SA |
#22 |
Liked 70 Times in 31 Posts
Would you use the brace with an ultra bell?
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#23 | |
Liked 531 Times in 108 Posts
Jim Kaekel 3836 STK |
#24 |
Liked 53 Times in 28 Posts
If it was a violent break on the starting line you definitely better look. I have broken one 350 and one 200 planetary that way.
#25 | |
Liked 5,121 Times in 1,952 Posts
It needs to be inspected physically , at least annually, in my opinion High maintenance item on the 200. If anyone knows of an upgraded unit, I'm listening.
#26 | |
Liked 42 Times in 17 Posts
Its weird. car launched great, wheels came up way higher than normal. 330' time was the best ever, then BANG! gears were lost. pulled over as fast as a I could to the wall, checked for leaks, towed to the pits in neutral. |
#27 |
#28 |
Where can you buy the brace? Thanks.
#29 |
#30 |
Liked 15 Times in 5 Posts
What kind of performance gain can someone expect by going from 2:74 low gear to a 2:91 in a 74 Camaro running stock eliminator with a 350 and weighing 3740lbs.
