Old 05-14-2017, 12:35 AM   #1
HP HUNTER
Liked 372 Times in 129 Posts
Default Shimming Hydraulic Flat Tappet Lifters
What gains in dyno HP, MPH, RPM peak gains have you seen from shimming hyd flat tappet lifters on a stocker cam?
Old 05-14-2017, 02:10 PM   #2
Tom Meyer
Liked 354 Times in 120 Posts
Default Re: Shimming Hydraulic Flat Tappet Lifters
When working on my sons LS1 street car we struggled with the short travel lifters and valve lash. In the end with adjustable rockers we found around 90 hp, this was on a roller lifter. Tom
Tom Meyer 5240 SS Stock ???
Old 05-14-2017, 03:13 PM   #3
Tom Turner
I think the original reasoning behind shimming the hyd lifters was to stop the lifter from collapsing and thus breaking the stock rockers or blowing the pushrods through the seat. It also (if properly adjusted only gave the lifter about .0075 to "float".) The HP gains came later when we discovered that stiffer valve springs, very light motor oil and much higher RPM thresholds yielded big gains in performance. One of the few "win-win" deals in drag racing. Solids are legal now so most won't use this method anymore.
Tom Turner is offline   Reply With Quote
Old 05-16-2017, 08:58 AM   #4
rich freitag
When did NHRA alllow solid lifters on a stocker hyd ?
Rich Freitag 1440 SS
rich freitag is offline   Reply With Quote
Old 05-16-2017, 09:28 AM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
Allowed this year. Lifter style must remain the same (can't replace a flat tappet lifter with a roller lifter).
"That'll never work....."
Old 05-16-2017, 09:32 AM   #6
HP HUNTER
Shimming the hyd lifter to .010 on my Buick 315/455 was worth 12 HP and carried the power out past the peak much better and the engine was happier. Spring pressure was 170/350. I opted to stay with the hyd lifter only because it was living nicely with my cam, if that wasn't the case I would be running a solid lifter.
Old 05-16-2017, 10:35 AM   #7
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
I run GM Rollers Lifters in my LT1
What advantage do Short Travel Roller Lifters they have over the GM Roller Lifters?
d
Old 05-17-2017, 02:07 PM   #8
Tom Turner
About 30HP, Maybe more depending on your tenacity.
Old 05-19-2017, 05:16 PM   #9
Coleydog
Liked 53 Times in 38 Posts
What they're saying, no loss of lift or duration with shimming. Now, just use a solid lifter
Mike
Old 05-19-2017, 06:44 PM   #10
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Converting from a hydraulic lifter to a solid sounds good , but how does that work ? Wouldn't you have to develop a new camshaft ? Wouldn't you lose some lift due to whatever valve lash you use ? Are there some stocker profiles out there that are solid but are designed for very tight lash , say under .012" . Just asking , I am interested !
ss3011 is online now   Reply With Quote
