Old 05-15-2017, 09:50 AM   #1
pfordamx
Liked 7 Times in 5 Posts
Default new combo missing a bunch of power?
So after a major overhaul, our car starts and ideals and does everything well its just way down on power. and i was wondering if you guys could give some ideas on where to look. the car is 1969 amx with a 427inch amc stroker 13.1 compression .740 and .760 lift solid roller duration is 278 and 284 @ .050 108 lobe separation installed at 104.5. Hemi Adkins did the heads they flow 305 @ .700 on a stingy bench. it weighs 3264 with me in it its got 727 torque flight with a brake and a turbo action 8 inch converter that should stall at 5900 and 28 inch tires and 4.10 gears and spool. the rear suspension is all calvert stuff. i don't think the lack is in the chassis or transmission because the car is ok in the 60ft if it was down 300hp becuase it went 12.00 at 106 with 1.51 60ft lifting the wheels about 6 inches. i've thought it could be in the converter. it just does not pull like it should, the motor hasn't been dynoed but i would think it should make 600hp. when its right i wondered about valve springs but if that was the case it would hit a rpm wall right? i'm open to any and all ideas. The things i've considered that could be wrong are.
The plug wires are over 5 years old those will be changed soon.
I'm curious about our digital 6 thinking about having it tested
its 1000cfm e85 carb we have a gas dominator we intend to test in its place. the timing is locked at 38 and has been checked repeatedly. that setting might be a little soft alot of amc's like 40 but it shouldn't make 2 seconds worth of difference. the fuel system is overkill magnafuel 500 pump and regulator and -10 line holds 6.5psi with out flinching. i'm kinda at a loss any help is appreciated
Thank you
Patrick Ford
pfordamx is offline   Reply With Quote
