Old 05-08-2017, 09:53 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Question about fuel injection from a newbie
Was Testing LS1 and LT1 Injectors
The LS1 Injectors misted better than the LT1 using same fuel pressure.
Couple LT1s Injectors clogged up causing fuel delivery issues.
So went with LS1 Injectors...direct replacement for the LT1's.
If you increase the Fuel Pressure and not Change the MAP.
They Injectors will only supply the fuel in the MAP.
May get a finer mist but the PCM would eventually relearn and provide the fuel the computer was programmed.
D
Wow! You have no clue. For one thing, MAP is Manifold Absolute Pressure.
Ed Wright 4156 SS/JA
Old 05-09-2017, 11:30 AM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Talking about the MAP that I see in TunerCat showing the Fuel Curve
D
Old 05-09-2017, 11:32 AM   #3
Ed Wright
Ed Wright's Avatar
D
That is a map. Not all caps.
Old 05-08-2017, 06:02 PM   #4
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
I use injectors from FAST in mine.
That's actually where my 60 lb injectors came from that I put in my LT1.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
