#1 | |
Got this from Doug Roe' s book Rochester carburation H.P. Books ...Trevor |
Liked 306 Times in 172 Posts
Is your linkage reworked to the secondaries or still factory stock. If still stock, could the rear throttle blades somehow stick closed when you pedal?
Liked 5,087 Times in 1,938 Posts
Not sure of the exact problem here, but I would say to look at each possibility.
Start with the sec. flapper, and make sure it doesn't come anywhere near the top opening. You can loosen the screws and shift the plates around a bit, and then re-tighten. Or, just file the casting a little bit, where ever it's close. Of course, you wouldn't want to do this on a S/SS carb. I'm sure you know this.
Just remembered this. I once had the split pin that secures the cam for the hanger walk out slightly and that interfered with the flap.
Liked 799 Times in 236 Posts
What's the float level measurement? And fuel pressure?
"That'll never work....." |
