Old 04-22-2017, 12:58 AM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Re: REM CRYO Gear Treatment
I just do REM "Because"
Because the gears mesh better and seem smoother when they rotate.
I've done all the gears in my Proflite and it has noticeably improved rotation when building it. I've done a few other sets for some Comp racers. I'm sold on REM finishes for durability.
Here is an ad that gives HP numbers if that is what your looking for.
https://innovatorswest.com/REM-gear-polishing.html
I have wondered about using this process: http://www.microblueracing.com/smoot...solutions.html
I would like to hear from someone that has used it on rear gears.
Hope this helps you Dan
Adger Smith (Former SS)
Old 04-22-2017, 03:43 PM   #2
Rsmith38
Liked 28 Times in 15 Posts
Adger - I have used the micro on a new Dana 44 5.13 Have never had a rear turn with so little drag when assembled. Don't know if any ET - no back to back test. just felt the gear would last longer - if nothing else!
Rsmith38 is offline   Reply With Quote
Old 04-23-2017, 05:34 PM   #3
bry-war
Liked 2 Times in 2 Posts
When your friends have to push your car they will appreciate the low friction. Polished gears and radials make a huge rolling difference.
bry-war is offline   Reply With Quote
Old 04-23-2017, 10:02 PM   #4
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
It does..thanks.
D
Old 04-27-2017, 10:03 AM   #5
Dan Fahey
Dan Fahey's Avatar
Adger Smith;
Thank you for referring both of these companies.
Especially like the MicroBlue coating for additional friction reduction.
Having a PLUS SIZE Car can use every bit of parasitic drag reduction possible.
I know NASCAR and Sport Cars use a lot of these products and services.
NO longer see the dramatic blowing of engines as you did in the 60's and 70's.
Which I think kicked in in the 80's. (thank you aero industry).
If anyone has a recommendation please forward the information and experience.
D
Old 04-27-2017, 11:18 AM   #6
PozQB14
Liked 42 Times in 17 Posts
Hey Dan, Mark Williams does the REM polish but they have their own term for it. I chose to get my pro gears shot peened and lightened. There's a possibility that to much material may be removed with being strengthened and polished. After breaking a set of gears in the middle of a run, I chose to get them peened over polished. But they do both.
PozQB14 is offline   Reply With Quote
Old 05-12-2017, 06:38 AM   #7
Brandon Alsept
Brandon Alsept's Avatar
This is a video of a 8.8 I just lightened the ring gear, the spool and had the bearings all done in microblue. This isn't a true representation of performance but it spun at that speed for over 2 minutes.
Brandon Alsept is offline   Reply With Quote
Old 05-12-2017, 12:43 PM   #8
Dan Fahey
Dan Fahey's Avatar
Will Mark Williams also Microblue the Gears and Bearings?
D
