Liked 31 Times in 19 Posts
Clint
Thankyou for the good words I appreciate it. Any kind of factory "style" of cast X rams fit in these cars in the OEM location. Sheetmetal ones are a whole different story. You will find that as you are working on that car that if you change the location of one item it literally affects 10 other things . Its freakin tight with very little wiggle room if you are trying to retain as much of the original unmodified car as possible. I cant run a mechanical fan on mine with the big rad required to keep this thing cool. Even had to notch the electric fan shrouds for pulley clearance. liteweight |
#2 | |
Liked 5 Times in 5 Posts
