Old 03-30-2017, 01:20 PM   #11
J&S Racing
Liked 319 Times in 82 Posts
Default Re: 69 camaro rag joint
I know I have the correct rag joint.
My initial question was about the column it self. Thought I've seen 33" and 32" lengths. I wasn't sure if the column was different power to manual.
It appears the column has been compressed. Tried tapping on it with no luck. Later today I'm gonna try and get a strap around it and try to pull it out.
Old 03-30-2017, 02:49 PM   #12
FED 387
Liked 329 Times in 177 Posts
That car has a collapsible steering column probably was in an accident at some time and collapsed. Take it out and look at the spring mesh see if it is collapsed. You might be able to pull the shaft out enough to allow you to bolt it to the rag joint.
Old 03-30-2017, 03:35 PM   #13
danoone
danoone's Avatar
The shaft is definitely pushed up it the column. It is a slip fit. Maybe tight from being jammed into the lower bearing at the bottom. That is your only problem
danoone is offline   Reply With Quote
Old 03-30-2017, 04:41 PM   #14
J&S Racing
Thanks guys.
I have another column that also appears to be collapsed. Hopefully 1 will slide out.
Old 03-30-2017, 06:10 PM   #15
Hacksaw
Liked 306 Times in 172 Posts
Try bolting a slide hammer to your flange, should get some action with that.
