Liked 8,127 Times in 1,534 Posts
The brace on the pass side is a must have item....If you really want to sleep at night call Leo G. For the replacement bell housing. Money well spent and far superior to the factory metric case.....
Liked 66 Times in 37 Posts
J&W Ultra bell
72 cutlass |
#3 | |
Liked 62 Times in 29 Posts
Liked 1,471 Times in 308 Posts
We do run a brace, and haven't had a problem in 3 years.
Liked 2 Times in 2 Posts
What does the brace look like,and where does I t go?
Liked 905 Times in 193 Posts
I cracked two before going to an ultra bell.
Bob Don 128 SS |
Liked 799 Times in 236 Posts
"That'll never work....." |
Liked 42 Times in 17 Posts
This is kind of off topic but still a metric question. Has anyone ever broke a rear end gear set and as a result hurt the transmission, specifically a metric 200?
Liked 60 Times in 12 Posts
Turbo Action also has a bellhousing for Metric 200. Check with them.
2894 STK |
Liked 535 Times in 110 Posts
Common problem not only related to TH200's. Anytime you tear a ring & pinion out, it's a good idea to drop the pan on the trans at the same time. Banging from the rear end often causes roller clutch (sprag) failure.
Jim Kaekel 3836 STK |
