Old 03-16-2017, 03:25 PM   #1
Bobby Lundholm
Liked 126 Times in 49 Posts
Default Re: Roller rocker arm and stud
I have Harland Sharp on my engine combo that's the same as yours.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is online now   Reply With Quote
Old 03-17-2017, 12:16 AM   #2
killintime6968
Liked 91 Times in 29 Posts
I think the comp cams setup is very nice but a bit overkill on a lower hp 396. Also pretty pricey when you have buy the complete kit to get the 1/2" studs because they come with new 1/2" trunions etc. As you can buy the XD rocker arms setup for 1/2" studs already.
killintime6968 is offline   Reply With Quote
Old 03-17-2017, 07:08 AM   #3
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
The studs are available without the trunions and bearings and rebuild kit
comp 4543-16
overkill? depends upon how "square" of a lobe you are using and if one is "cheating" (who would do that) and is using a larger dia lifter to take advantage of that increased "rate"
edit..I understand Crower has a stock package out also...I have never seen that setup yet
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
