Old 02-20-2017, 01:29 PM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 881 Times in 236 Posts
Default Re: Pac vs Manley
I have to say the last set of Manley 448 springs I got were the best ever from Manley.
Over 200 runs with no broken springs and only 10-15# loss of pressure across the board.
And that is on a 8300rpm Big Block with a .900 lift cam .
I've used PAC , PSI and Manley , It seems Manley may have caught up with the reliability. AND they always pay the contingency , had issues with the others.
Old 02-20-2017, 02:48 PM   #2
richie 2
Liked 205 Times in 93 Posts
yes time for a new set on my 327ci...same recommendations? matching retainers & locks or r they a different brand...tks.
Old 03-09-2017, 03:57 AM   #3
trmnatr
Crane Cam's springs are also good. They have some made by PAC and some not. Their 1.55" and 1.625" is made for them and are excellent (96886 and 99880), and their Posi-Stop or standard retainers fit correctly including ID locators.
I like both Crane and Manley
trmnatr is offline   Reply With Quote
Old 03-09-2017, 08:38 AM   #4
Ed Wright
Ed Wright's Avatar
I have been using PAC 1356 springs (1.5" dia) for a few years now. I put new springs on every year, just to be safe. Just an LT1, mine never sees over 8500. Usually 8300 at the stripe. Have never broken one, and have never seen much pressure loss. I have three sets sitting here I would have no problem using again. I can torque the center head bolts with these 1.5" diameter springs installed, and don't have to clearance the rocker arms for them. Best springs I have had.
Ed Wright 4156 SS/JA
Old 03-09-2017, 10:10 AM   #5
63corvette
Liked 357 Times in 103 Posts
I have used PAC, PSI, and Manley.
PSI never paid me contingency, even after repeated calls and emails so I stopped using their springs.
Manley always had breakage issues. In 2010 I could not make over 5 to 6 passes before changing a broken spring. Manley even admitted they had an issue and wanted to give me more springs free. I declined and changed to PAC. Issue solved.
PAC over the years have been slow to pay contingency, however in 2016 they paid quickly.
PAC is and would be my choice.
I still use them and have not broken one in years and they hold their pressures for a full year.
Just My 2 Cents
Rick Cates
63corvette is offline   Reply With Quote
Old 03-19-2017, 09:05 AM   #6
drgrcr1156
Liked 2 Times in 1 Post
Tom,
What rear gear are you using with that combination?
Bob
drgrcr1156 is offline   Reply With Quote
