Old 02-16-2017, 02:49 PM   #1
jmcarter
jmcarter's Avatar
Liked 3,260 Times in 990 Posts
Default Re: Powerglide first gear
I'd agree with the 1.98's but you need to know your torque readings or have a good idea that you can stand that kind of drop when you go into 2nd. Be prepared for the car to slow down if you had a good 3 speed before.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-16-2017, 05:30 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Yeah, I can't imagine a 3000+ pound car with 500 hp is very far below the index as it is.
With a 1.98 first gear and 4.56 in the back, it will work the same on the starting line as it would with a standard 1.76 first gear and 5.13 in the rear. The 1.76 combination would recover better on the shift also.
I doubt a 500 hp motor will like a lot of RPM, but there are a lot of variables.
S/ST 51
S/C 53
