Liked 31 Times in 10 Posts
Anyone have a 1970-75 Chevrolet parts book that confirms which part numbers were on the Chevy 400 2gc? Trying to confirm which CFM carbs were available. On the blue print specs it only shows a 1.25 carb which I believe is the 381 cfm.
Thanks,
Michael Brand II 505B - F/SA |
Liked 719 Times in 220 Posts
Look out for an OEM carb, then measure the ventures. Some of these are the 1.375" venturi, and the alternate carbs shown on the blueprint specs on your Tech Bulletin specify the smaller venturi,even though the car originally came with the larger one. Some replacement parts differed from the OEM.
Liked 285 Times in 87 Posts
Michael… 1970: 7040117, 7040118, 7040119, 7040120. 1971: 7041118, 7041137. 1972: 7042118, 7042838. 1973: 7043118, 7043119. 1974: 7044118. 1975: (4 barrel only). 1.25=381cfm, 1.312=423cfm, 1.375=435cfm. The are all referred to as "Large Base" starting in 1970. I hope this helps…Maurice.
Liked 2 Times in 2 Posts
Maurice, what is the test pressure being used to arrive at those flow numbers?
Liked 333 Times in 180 Posts
3.0-fed387
Liked 54 Times in 27 Posts
Under vacuum, 3" was used for 2 bbl since originally at WOT that was about the vacuum achieved; 1.5" was used for 4 bbl carbs. The conversion factor is discussed in Doug Roe's book, and for example the 1-3/16" venturi carbs would give 247 cfm on the 4 barrel scale, 1-5/16 about 299, and the 1.25" iirc around 280.
Thanks for the help so far. The particular carb number that is listed for the 74' 400 is 7044118. If anyone has this carb laying around can you please measure the venturi size for me?
Michael Brand II 505B - F/SA Last edited by M Brand 505B; 02-13-2017 at 07:01 PM. Reason: Typo |
Liked 240 Times in 112 Posts
Dave Noll, EF/S ,?/SA 6526 |
