#11 | |
Liked 25 Times in 16 Posts
http://www.compcams.com/Technical/Ca...terCatalog.pdf Pg. 57 MAX AREA LIFT RULE SOLIDS Continued CAMSHAFT TYPE LOBE # RATED DURATION, DURATION IN DEGREES, LOBE LIFT, TAPPET LIFT @ TDC, THEORETICAL VALVE LIFT @ "0" LASH, ROCKER ARM RATIO, @ .050, @ .200 106°,110°,1.5,1.6,1.7 5652 285 258 154 .266 .122 .110 .399 .426 .452 I didn't see a 5786 lobe, but there were some in the range of numbers around that page.
Mopar 2 Ya! |
#12 |
Liked 25 Times in 9 Posts
#13 |
Another vote for Red Line Cams. We will give them a call when we get closer. We did some flow testing on the 920 head and did a sonic test on the three blocks. One of the blocks had thinner decks (~.380") than the other two. I am looking for a set of 302 casting heads to flow and some of the stock iron intakes. My builder didn't like the mismatch in the ports between the 920 head and the LD4B. Quite a difference in port width. I guess Edelbrock assumed that people would do a port/gasket match on the heads.
Mopar 2 Ya! |
#14 | |
Liked 1,922 Times in 432 Posts
Actually, Tim Cole has been running the competition department at Comp for years, he and Chris Padgitt have been the Stock and Super Stock experts there for years, and have not gone anywhere. Billy Godbold has been their cam designer for quite a while. John Partridge bought Bullet Cams from Darrel Hawkins, John had been working for Atech Motorsports, the commercial side of Summit, after having left Lunati years earlier. John is a nice guy, and Don Walthall is a very good cam designer. But no, they do not employ "all" of the Stock and Super Stock cam experts from "all" of the other companies.
Alan Roehrich 212A G/S |
#15 | |
Liked 184 Times in 113 Posts
Thanks for the update..! What I stated was what I heard from a while back. Did not know otherwise. Glad to know the facts. Dan |
#16 |
Alan, thanks for the info. My engine builder talked to someone at from Comp at the Division 2 Hall of Fame meeting a week or two back. He went to see Scotty McLendon get an award. At any rate he got some contacts at Comp to talk to. I'll pass on those contacts as well, probably the same guys. Apparently he talked to several racers there and they all thought I was bonkers for building a stocker. Probably true, but I don't have much interest in the other classes. I had John Partridge grind me a Pure Stock cam for a 340 when we had an IHRA track near Dallas. That went away and so did that plan.
Mopar 2 Ya! |
#17 |
Liked 323 Times in 63 Posts
I have always bought my cams from Chris Padgitt at Comp Cams. I just tell him what I am building and he has a cam made for it. I have never been able to improve on what he sends me the first time.
Bob Shaw V/SA 515 |
#18 |
Liked 805 Times in 341 Posts
I saw recently that Charlie Westcott Jr. makes Stock Eliminator cams.
http://www.militiaproducts.com/camshafts |
#19 |
Liked 294 Times in 93 Posts
Spiro Jannings, redline race cams. Always made more power, and never any "livability" issues with his designs and he understands S&SS.
RJ Sledge |
#20 | |
Is a hydraulic cam legal in a solid lifter engine in Stock? I had the thought that we will be giving up a small amount of lift due to the lash in a solid lifter cam. We don't get much lift in the 273 combos, so maybe every bit counts? We can run the hydraulic lifters with maybe .002" preload/travel? Any thoughts on this?
Mopar 2 Ya! |
