Old 01-09-2017, 11:28 AM   #1
Hacksaw
Liked 310 Times in 174 Posts
Default Re: Mikronite vs REM
Curious: What's slightly different on the set -up involving treated gears?
Old 01-09-2017, 12:50 PM   #2
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: Mikronite vs REM
I used Synthetic 75-90 Mobil 1 on mine. The gears were Chryo and REM finished.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 01-09-2017, 02:13 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Since the surface is flatter and finer you can set the Ring and Pinion with a tighter clearance.
There is less friction, less heat and part expansion.
Slipperier tighter touch should provide a better feel and response time.
Dan
Old 01-09-2017, 02:39 PM   #4
Jim Bailey
Liked 584 Times in 94 Posts
Dan, the best results we had were with the Pinion Depth slightly deeper than recommended, into the ring gear, then making sure the backlash was set a the tightest spot you can find rotating the ring gear. "IF" then the backlash seemed too lose the rest of the rotation, we didn't worry about it. The only time we got into trouble was with the set up being too tight. My guess is the Cryo'd and Rem'd gear sets don't "wear in". For lube we always ran 75/90 synth. keeping in mind that we always ran max capacity. None of that 1/2 to 1 quart B.S. Your ring and Pinion is a very high load area in your race car that requires lube at all times. Not saying this is right, but it worked for me ... hope it helps.
Jim Bailey is offline   Reply With Quote
Old 01-09-2017, 04:00 PM   #5
Bench Racer
Liked 99 Times in 21 Posts
I have no experience with setting up gears but was carrying on a conversation with a guy that set up diffs and trans for Nascar and circle track guys. He said one of the benefits of "treated" gears vs. a non treated ring and pinion the set up was the treated gears pretty well stays constant. He said on a non treated diff you need to keep a frequent checks to insure the clearances stayed where they should be.
Bench Racer is offline   Reply With Quote
Old 01-09-2017, 05:58 PM   #6
Dan Fahey
Dan Fahey's Avatar
YEAH it does actually. Mine is filled.
The SS uses a 8.5 Rear 10 Bolt which is a strong rear.
Full Stock figure you would need the 12 bolt 8 3/4 rear.
Might add a heater to keep it warm.
D
Old 01-10-2017, 02:59 PM   #7
340Cuda
Liked 802 Times in 339 Posts
Who are some of the vendors you all have had good luck with treating ring and pinions?
Thanks,
Bill
Old 01-10-2017, 07:36 PM   #8
Greg Barsamian
Liked 427 Times in 97 Posts
I used Performance Engineering & Manufacturing.
Charged $164.00 total to do both Cryo & REM treatments.
Turn around time once they received the ring & pinion was 14 days.
Contact Randy to get a CN number for any parts you send to their plant.
Randy Harrison: rharrison@pemracing.com
Performance Engineering & Manufacturing, LLC
425 Industrial Park Drive
Saint Clair, MO 63077
ph; 636 234-0975
fax 636 234-0982
www.pemracing.com
Old 01-10-2017, 07:57 PM   #9
Jeff Stout
Liked 704 Times in 281 Posts
Any other places to send here on the west coast AZ area? Thanks Jeff
