Having raced 265" '55 & '56 Chevies, we damn sure flycut our flat top pistons for valve-to-Piston clearance. Mine was down 4 times by NHRA, three national records & once was protested, passed every time.
Ed Wright 4156 SS/JA |
Liked 8,217 Times in 1,537 Posts
Ed, we are talking STOCK eliminator.....Alan is correct. I might add just watch yourself in the water....
#3 | |
I don't get the remark about water?
Liked 663 Times in 187 Posts
I think he is referring to don't let it get away from you on a burnout. People tend to over rev a car in the water box.
As for vtp like Alan said above .060 .065 exh would be as tight as I've ever ran and it was okay for me. The intake is more forgiving. if I were you I'd advance the cam and get yourself some more exh clearance and less int in my opinion if you are worried about it . Good luck with it.
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
#5 | |
Liked 184 Times in 113 Posts
Curious. Why more Clearance on the Intake vs Exhaust. ?
Liked 7 Times in 5 Posts
Liked 783 Times in 195 Posts
Should be more clearance on the exhaust than on the intake. Observe the relationship of the valve action in comparison to the rotation of the engine during the cycle. The piston is closest to the intake valve as the piston is approaching TDC and the valve is closing, so any contact will "push" the valve closed and/or the clearance will increase rapidly. For the exhaust valve action, the opposite is true. The piston is closest to the exhaust valve as the piston is approaching TDC and the valve is opening. The camshaft will push the valve into the piston and potential damage is greater.
There are other factors like what causes valve float, etc., but the above is generally true.
![]() Last edited by Dwight Southerland; 01-02-2017 at 07:23 PM. |
#9 | |
Liked 22 Times in 22 Posts
don,t have one |
Liked 2,343 Times in 465 Posts
Hi Asking these questions I would assume your a newbie to stock. As Alan said did you check it the right way? In my younger years I might have run it with .060 but with the cost of everything today I wouldn't risk it. There are several ways to pick up that little clearance you need. I know it sucks but I would take the heads off and have a good machine shop cut .010 off the back of the valve. If possible move the cam a couple of degree's. What head gasket are you using? Have one custom made .05 larger but tighter on the bore so you don't loose compression. They don't cost that much. Good luck BP
