Old 12-29-2007, 09:39 PM   #18
Kevin Lang
Smile Re: brake problem
Denny, check the adustable prop valve to make sure it is not closed up, by turning the knob somewhere close to center on the adjustment. Otherwise you will have less pressure and slow bleeding at rear brakes thus taking forever to get the air out. good luck!!!
Kevin Lang is offline   Reply With Quote
