Old 12-28-2007, 04:39 AM   #1
bill dedman
Liked 6 Times in 4 Posts
Default Stock MOPAR electronic ignition
Can anybody tell me if the distributors in the early Mopar electronic ignitions had a magnetic pickup or a Hall Effect pickup? I have read it both ways, and I don't know the difference, or how to TELL the difference. Mine has a magnetized reluctor or pickup (can't tell which) that acts on the other part when it passes by, but how do you tell if it's a Hall Effect unit?
I am installing an MSD spark retard (Boost Master) and the hookup wiring is different for the magnetic vs. the Hall Effect distributors, and THEY (MSD) don't know how to differentiate between the two.
Any information will be appreciated!!!
Bill
Bill
bill dedman is offline   Reply With Quote
Old 12-28-2007, 09:29 AM   #2
art leong
Default Re: Stock MOPAR electronic ignition
The 1970's ones were magnetic pickup. Thats where the brass feelers guages came in to play.
The ones for the 1980's 4 cylinder turbo cars are hall effect.
The boost master didn't work at all on my turbo car. It just fought with the computer. And the car slowed up a lot.
Art Leong 2095 SS
Old 12-28-2007, 09:30 AM   #3
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
See if this site has the information you need. Try the electronic conversion part.
http://www.mymopar.com/tools.htm
Old 12-28-2007, 06:18 PM   #4
Tailchaser
The "Lean Burn" cars, I think have been both ways. But vast majority are pickup/reluctor combinations.
Chasin' my own tail for 30 years and counting....(shoulda raced oval track!)
Tailchaser is offline   Reply With Quote
Old 12-28-2007, 10:54 PM   #5
Moparteacher
The early mopar dizzys had magnetic induction (pick-up and reluctor). The reluctor looks like a 8-point star on the shaft. The hall-effect uses a shutter wheel. It's looks like a steel umbrella with slots or windows. The magnetic induction produces an AC signal. The hall effect produces a DC square wave.
The hall effect distributor requires an external voltage feed hence a third wire.
The lean burn dizzys use two magnetic induction pick-ups. The Mopar engines book has a wiring diagram to utilize the lean burn distributor. It allows the user to switch from one pick-up to the other for starting retard.
Hope this helps.
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
Old 12-29-2007, 01:00 AM   #6
bill dedman
Yes, it helps!!!
It ALL helps.... a LOT!
You guys are the absolute BEST!!!!!!!!
A shame I have to come HERE for information of this nature; MSD Tech hasn't a clue...
Leave it to DRAG RACERS to get it right... the first time!!!
Thanks a bunch to you all! This will solve all my Boost Master wiring problems.
Except one...
The distributor I have is an early-model (1974) and the color coding is long gone from the insulation on the wires that enter the base of the distributor.
It is an umolested unit. Any idea which wire is the + wire? I have to hook it up to a specific wire on the MSD 5462 control module. The wiring-plug coming from the dist. has a male and a female plug; might one of those be a positive? I'm thinking that the wiring to that plug would, of necessity, HAVE to be consistent in its polarity. Other than that, I don't know how to tell.
Any ideas?
Thanks again for all the good info!!!
Bill
Bill
