Old 11-25-2016, 06:53 PM   #1
James L Miller
Liked 25 Times in 16 Posts
Default Re: Mopar 273-4bbl Combo
I did catch my engine builder while he was taking a break at the beach on the east coast of Florida. He was thinking along your lines but using a 340 block and get custom sleeves with the flange as you mentioned. That would be really stout cylinder walls for a 273 size engine. He said he did that many years ago when he ran his Colt in MP with a 280 CID (3.935" bore, probably the old 2.96" stroke crank) with W2 heads. I wasn't sure how big of a step was needed at the bottom near the main webbings.
I think I will start with a 273 block with Hardblok on the first go. I don't want to spend a ton of money on this project. The idea is to run quick enough to qualify in Div. 4 divisional and national events here (don't plan on going to Indy).
Mopar 2 Ya!
Old 11-27-2016, 09:42 AM   #2
Frank Castros
Liked 2,725 Times in 961 Posts
James,
I also love the combination and wish you well with your build.
Sleeving a 340 X block would be the ultimate, but very expensive (if you can find one) Hardblock in a 273 is the way to go on a budget.
Also speak to Dean Oliver about a carburetor.
No disrespect to all who have offered their advice but Paul Wong is the guy I would consult.
Old 11-27-2016, 01:50 PM   #3
grncpe
Liked 44 Times in 10 Posts
I have looked at this combo for a while. What style header are you going to run? There were some fender well headers for them but choices are limited now. The primary tube diameter being to large from a 340 is a problem. Luckily for you guys I have the stahl fixtures & masters for the early a cars with a small block 😋. The 66 valiant sedan in ss looks like the best combo to me. The problem is committing that much money to that engine program. With a x block & Honda rod journal, killer heads & intake, and lots of rpm. The package is light enough to be a killer! But what old killer package is cheap? None.....
Tommy Baker SS/GA # 172
E/SA # 1272
grncpe is offline   Reply With Quote
Old 11-27-2016, 03:24 PM   #4
James L Miller
Thanks for the info on the carb. Matt had mentioned Deano did his carb. Now I know he meant Dean Oliver. I have some 340 blocks, used to have a TA block, but sold it to a restorer in Houston many years ago. I'm going to go with the Hardblok. Thinking about using K1 rods and CP pistons. Not sure about what bore size and what rings? Anyone make spacers to fill the 5/64ths groove with a 1mm or 1.2mm top ring?
The Edelbrock head looks like it might be a good future upgrade with only a 5HP hit. It will add some 68 pounds to the car, but with my fat butt driving I think it will be heavy already. I wonder if Edelbrock sells the head without the valve seats installed?
I see that TTI, Dougs and Hooker makes headers for the early A-bodies. I didn't see anything on the Stahl site. I think they are all 1-5/8" primaries. The TTI looks like it has the best plug access. All are $600-$900. No cheapie headers for that combo.
Mopar 2 Ya!
Old 11-27-2016, 03:24 PM   #5
David Lee
Liked 346 Times in 126 Posts
what is your definition of cheap?
Old 11-27-2016, 05:54 PM   #6
grncpe
$600-900 is cheap for headers in comparison to others out there. The west coast stainless headers are $ 3400 just an FYI. You won't see any headers on stahl' site. All the fixtures were sold. I bought all the Chrysler fixtures along with all the collectors stahl had. I'm not trying to sell headers on here just saying that may be an option for you. I allready have one person that contacted me about building a set. I think I may have some 273 parts left if you need some. I would like to see this combo out there, I think it would be cool if it had a stick behind it also!
E/SA # 1272
Old 11-27-2016, 05:58 PM   #7
David Lee
as i get my project closer to completion i will call someone for a set, but my question was on the whole car, do you consider 15 to 20k cheap?
Old 11-27-2016, 06:02 PM   #8
grncpe
Yes I think that is cheap to build a car, I run a 70 cuda in super stock, by all means it's not a cheap car to build. I do all the work myself also except engine & trans. You can't build a stocker motor for what you are saying. Average competitive stocker motor is 20k
E/SA # 1272
