Old 11-25-2016, 03:19 PM   #18
Terry Bride
Default Re: Mopar 273-4bbl Combo
I'm slowly working on this same combination for a 66 Barracuda.
You need to keep in mind that the sleeve will need a step to retain it in the parent bore. You can't stick a 3.910" O.D. sleeve into a 3.910" bore. There will be nothing to support the sleeve. You will need a sleeve with enough oversize beyond the parent bore dia. to allow an adequate step to register against. I have not found any straight sleeve with enough wall thickness to do this. In this case, the only way to do the sleeving correctly is to get a set of flanged liners and counter bore the deck for the flange.
A custom sleeve will be an expensive investment along with some fairly substantial machining costs but in the end, you will have a block that will maintain it's bore size for many re-hones.
I will have to sonic test the 1967 273 block I have to see what it has for thickness.
In the mean time, I am saving up to purchase the pistons and maybe sleeves.
Terry Bride is offline   Reply With Quote
