Old 09-26-2016, 09:46 AM   #1
Bobby Lundholm
Liked 127 Times in 49 Posts
Default Goodyear Slick won't stay inflated
It leaks down overnight and is completely flat. Is the bead not sealed correctly? Any help would be appreciated.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is online now   Reply With Quote
Old 09-26-2016, 10:52 AM   #2
Mike Croley
Default Re: Goodyear Slick won't stay inflated
An easy way to find the issue is to submerge the wheel/tire assembly in water ( soapy water is even better ) and the bubbles will show you where the problem is. If you have an understanding wife, the bathtub will work fine. The alternative is to wipe soapy water over the surface of the tire and around both beads while watching for the bubbles. Also check the valve stem to be sure it isn't leaking internally.
Mike Croley is offline   Reply With Quote
Old 09-26-2016, 11:35 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: Goodyear Slick won't stay inflated
Are they new, or how old??
LOCOMOTION Racing
Old 09-26-2016, 11:45 AM   #4
John Dinkel
Liked 263 Times in 68 Posts
Old Goodyears will leak through the tire.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 09-26-2016, 12:30 PM   #5
Bobby Lundholm
Older. Not really old though. They went flat over the winter. I filled them up and one is staying inflated and the other is leaking down,
Old 09-26-2016, 01:11 PM   #6
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
If it's leaking through the sidewall just use the old soap trick on the inside of the sidewalls................
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 09-28-2016, 08:07 AM   #7
Eman
Liked 133 Times in 76 Posts
First find where it's leaking. If it's the sidewall dismount the tire and rub Palmolive dish soap on the inside of the sidewall. I let it dry and rub a second coat, then remount and inflate. The soap seals the pores.
If it's the bead remove the tire and clean the wheel where the bead seats. Also clean the tire bead completely and then wipe both surfaces with a solvent like acetone. I've also used hair spray on the beads to keep the tire from turning on the wheel if no wheel screws.
That's another thing. Were these tires ever screwed before? Are they screwed now?
Old 09-28-2016, 08:54 AM   #8
Bobby Lundholm
I was looking at it again last night and I believe the bead came unseated. They have always leaked a little but not completely flat overnight. I will take the slick off, clean up the wheel and slick, and then mount it again.
Thanks for all the help.
Old 09-28-2016, 09:34 AM   #9
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I always put a thin bead 1/8''of ultra black silicone on wheel and it helps it seal.
you can use orange or blue or gray if you want LOL
Mike Taylor 3601
Old 09-29-2016, 07:55 AM   #10
randy wilson
Liked 22 Times in 22 Posts
It's leaking from where the tire is formed in the middle. The soap works, but so does a thin coat of gasket sealer.
don,t have one
