Old 09-07-2016, 12:49 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: Rear shock movement
I'm a bracket/index racer, so ET isn't my main concern. As bad as that rear movement looks, the DS rpm looks like the tire is dead hooking. I looked at the Santhuff stuff, but 2 G's was a little extreme for me. The other thing that's bad is that I tow the car with the straps hooked to the ladder bar brackets on the rear, so I may have worn the shocks out just towing back and forth to the track.
Going to the upper hole would be a chore for me. I'd have to figure out how to move the Heims to keep the DS angle right and keep the same pre-load. These bars have no external adjustments cause they're way old.
Ron Gusack is offline   Reply With Quote
