#1 | |
Liked 5,150 Times in 1,966 Posts
However, if a 6.14 is available, here's what I came up with. First of all, I try to set up a class car to be able to run 9-10 under. That way, it leaves room for improvement if you don't have the beans under the hood to run that at first. At least you will know where the problem lies. So, W/Stock is a 16.40 index. Let's shoot for 15.50. I know that you will have to run pretty close to 85 mph to go that quick. Using a 26 x 8 MT tire, and a 6.14 gear, 7000 in the lights would be about 88 mph. Trust me ..7000 is not too high for a non turbo 2300. Probably not high enough. With the 6.14's , at that weight , you wouldn't need a super low first gear. Just a bit of flywheel weight to carry it out smoothly, and all the rpm you want. That's my take... FWIW
