Old 08-13-2016, 06:06 PM   #1
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Trailer ramps
I am building a set of aluminum trailer ramps, 66 inches long, for a
3300 lb. Stocker. What thickness should the aluminum be? They
will be properly braced underneath etc. Thanks, J.R.
J.R. Haddad is offline   Reply With Quote
Old 08-13-2016, 10:56 PM   #2
Default Re: Trailer ramps
Not enough info, JR.
How wide will they be?
How and where will you be carrying them and storing them?
What gauge will the cross bracing be? How many braces?
Give us your blueprint idea,and that will make this a lot easier to proceed with.
Old 08-13-2016, 11:40 PM   #3
J.R. Haddad
Mark, they will be 12 inches wide, starting out as 16 inches wide with 2
inches turned down on each side. They will be attached to the piano
hinges on the back door of my trailer. The bracing will look like this
\----/ (add a few inches left and right on the top of the \ / and subtract
the little extras sticking out below the --- . The bracing will be one
piece and I don't know what thickness that will be. I am copying a
design I saw on a picture that looked strong and reasonably light.
I mention strong because the ramps belonged to a guy with a
Malibu Wagon that weighed 3600 lbs. J.R.
Old 08-14-2016, 02:54 PM   #4
Okay, if you're going to brake the sheets, I'd start with 20" and do a 2" return on the bottoms.
Then add a few 1,1/2 x 1,1/2, x 3/16 angles underneath, every foot or so, you should be good with .125 material.
You'll have to research the material grade.. At a certain hardness , it won't brake without fracturing.
Old 08-14-2016, 04:03 PM   #5
FED 387
Liked 333 Times in 180 Posts
U can bend 6061 "some" not much depends how tight you go A right angle NO. Best to use 3030 it's soft enough u can bend it and Tig it too- remember u probably will only have one set of wheels at a time on the ramps so you most likely are looking at 700-800 pounds per ramp. FED 387
Old 08-14-2016, 06:07 PM   #6
Gary Anderson
I think he meant "3003".
Gary Anderson is offline   Reply With Quote
Old 08-14-2016, 06:16 PM   #7
FED 387
Yep typo error 3003
Old 08-14-2016, 10:45 PM   #8
J.R. Haddad
Thanks everyone, I appreciate it. J.R.
Old 08-15-2016, 08:06 AM   #9
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
An easy way (maybe not the cheapest) is to buy 6" channel and weld or bolt them together through the flange. (Bolting is preferred since the standard is 6061). Standard length is 6" so there would be very little fabrication. This is way overkill for a 3600 lb car.
Old 08-15-2016, 12:00 PM   #10
Jim Caughlin
Liked 805 Times in 245 Posts
6061T6 can be bent but the inside radius of the bend has to be 4 times the material thickness so assuming 3/16 thickness, the inside radius needs to be 3/4". Assuming that you are building alum ramps to minimize weight, the 6061 option is going to be the best weight to strength ratio. 3003 does bend easily but has the strength of a wet noodle. 5052H32 might be a better compromise but I would opt for the 6061 alloy.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
