Old 08-12-2016, 05:33 PM   #7
GTOMayhem
Liked 22 Times in 14 Posts
Default Re: Intake Manifold Rule
Originally Posted by R. Thorne View Post
Fill the exhaust crossover in the heads. Do away with the water pump o ring to manifold (grind it down and put a pipe plug in). This will allow you to shift the intake back and forth to align the ports. Ron.
So, you block it off with a pipe plug in the timing cover and another in the manifold? If so, then in general(not Pontiac V-8 specific) you could use a pipe plug to plug any hole, such as a coolant passage, in any intake manifold?
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
