Old 11-19-2007, 01:55 PM   #1
jedwards3
Default Frame tie-in
Looking for an opinion as to who, what, or how the best way to strengthen a ' 65 Mustang coupe frame? I have seen 2-3 different kits (some bolt on and some 100% weld in) and don't know which is best. At some time or another this car may evolve into a full time stock eliminator , but for now a bracket car is what it is being built for. The car is a definite project and currently a " frame off " restoration. tnks for the advice!!!!
jedwards3 is offline   Reply With Quote
Old 11-20-2007, 12:18 AM   #2
House of Darts
Liked 20 Times in 15 Posts
Default Re: Frame tie-in
Welding always gives the stiffest frame/body.
House of Darts is offline   Reply With Quote
Old 11-21-2007, 12:34 PM   #3
Jeff Teuton
Liked 326 Times in 50 Posts
Ditto and I would spend the money for the moly tubing instead of mile steel.
Jeff Teuton 4022 STK
Old 11-21-2007, 01:55 PM   #4
Dave Goob Cook
Dave Goob Cook's Avatar
To keep the car legal, and to ever restore it to stock, use a good bolt in kit, supplemented with a couple of welds here and there.
NHRA Stock Eliminator requires all the parts to be "bolt on", so you can see what is coming there.
I can't see the point of using Moly to weld to mild steel, but that is just me.
Dave Goob Cook is offline   Reply With Quote
Old 11-23-2007, 05:55 PM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 167 Times in 61 Posts
2007 rulebook states: Section 5A Stock Cars.
Subframes on unibody cars may be joined. Maximum-size material to be used is 2" X 3" X 1/8". Round tubing may be used to tie front and rear subframes together and join subframe in straight line extending through the car floor, with floor welded to member.
No where does it state that it has to be removable.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 11-24-2007, 11:56 AM   #6
Dave Goob Cook
I stand corrected.
Old 12-11-2007, 11:05 PM   #7
Chipper Chapman
Chipper Chapman's Avatar
Liked 142 Times in 64 Posts
Traction devices are supposed to be bolt in only. Weld in the connectors though.
Old 12-17-2007, 10:46 PM   #8
Dennis424C
Dennis424C's Avatar
Liked 2 Times in 2 Posts
I have found that the bolt in connectors work better to weld in than the weld in type. I think the bolt in are made to fit a litle bit better so there aren't big gaps to have to fill. I would also recomend installing solid body mounts at the same time.
Dennis "The Menace" Clark
424C Pro E/T
424C S/ST H/R S/G
Dennis424C is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
