Old 07-13-2016, 10:54 AM   #1
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default Re: M-200 torque converter installation
Well, Tom Goldman turned me on to my problem. It was the pilot snout on later lock-up converter transmissions. Cut it off and problem solved, almost.
Still had trouble getting it on all the way. So, I took Mike Delahanty's advice and stood the trans upright. Didn't have a garbage can handy, so I used the cherrypicker. Worked like a charm.
I thank everybody that responded. That's what's great about this site. Everytime I get hung up on something, the answer is always here.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 07-13-2016, 07:32 PM   #2
I kinda thought Tom was right on this.
You can hack saw that thing off or use a cut off wheel, but unless you want to disassemble the front half , I would stick a Q tip with some grease on it in the hole first. Leave it sticking out, and cut it along with the nub. Then just grab it and pull it out, chips and all.
