Liked 288 Times in 109 Posts
Racers,
The Super 10 has 1.8 intake, T & D shaft rockers, off the shelf valve covers require grinding notches to clear intake rockers near the adjuster. [which I have done] So, while updating, what are my options for a valve cover with more clearance that will not require the notches? Thanks |
Liked 759 Times in 379 Posts
Larry, Williams valve covers are the cat's azz http://www.williamsperformance.com/ and my BBC valve covers have the rail clearanced for my T&D shaft rockers.
Thank you Ed. looks good and will fill the need.
Liked 1,945 Times in 586 Posts
I have the inexpensive fabricated valve covers from Jegs. They fit good and don't leak. You do have to notch the rail a bit for the pushrods with shaft rockers.
Mike Pearson 2485 SS |
