Old 06-21-2016, 12:46 PM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: 520 heads
Depends on what you have. As a general rule, the later heads are better than the early heads. But the T is not necessary. It's just that the T heads are all late production heads.
Old 06-21-2016, 12:52 PM   #2
MR DERBY CITY
Liked 8,047 Times in 1,528 Posts
To answer your question seriously, if the heads are to be , shall we say chemically enhanced....then you will be fine with either head or even an 896 casting.
Old 06-22-2016, 01:03 PM   #3
Jim Hanig
Liked 99 Times in 49 Posts
Dwight if you where to build a 283 stick car what would a starting trans and end ratio would you chose. Jim
Old 06-22-2016, 01:51 PM   #4
Dwight Southerland
Jim, you have a PM.
