Liked 13 Times in 11 Posts
After reading thru this thread , I have decided to intentionally leave that plug out of my Dart block.
Liked 18 Times in 10 Posts
Finally got over to look at the engine. Bottom end looks good. Lifter bores are worn oblong and scared, one lifter(where broken pushrod is) has no oil hole in it? Roller rockers are all scored/ worn and some valve tips are also worn. The builder drilled and epoxied a oil fitting for gauge into the cavity where the oil filter goes, remote system used, oil gauge hole at top of block is plugged. All plugs are in place and the front oil gallery are staked in place. Can shows normal wear and lifters are not ruined. He is going to get a replacement engine rather than spend any money on this block.
Any other thoughts? Thanks all.
old 1608 stock racer |
Liked 1,826 Times in 414 Posts
Yeah, start with something like a Dart SHP block, and a good forged rotating assembly. Build a truly nice solid foundation. Then you can do most anything you want, within reason.
Alan Roehrich 212A G/S |
This is just a street engine, once done the car is going up for sale as he is downsizing.
#6 | |
If he came to me to have a supercharged street engine built, I'd do what I posted above, or send him elsewhere. I'd never touch a job putting a cheap short block under a supercharger. Not worth the hassle or the risk.
I cannot place enough emphasis on oil management / control. I have learned the hard way. Taking oil flow "for granted" or having "faith" is a big mistake.
Esp. with a vac pump and a wet sump. |
