05-12-2016, 08:44 PM | #1 |
sooty oil?
What is the cause of this? This is fresh oil with six 1/8 mile test hits. Amsoil 10 40. The oil looks black. the picture is right as I tilt the bucket to one side and let the oil flow to the side. You can see all this soot in the oil. Is it contamination from blow by as I did have a cylinder leaking down. I was just running e85 for the first time.
05-14-2016, 05:23 PM | #2 |
Liked 173 Times in 86 Posts
Re: sooty oil?
Being no one answered my suggestion would be to get a sample and have it annualized.
When I use to deal with Black Bear in Farmingdale they'd run samples, no charge. Also you could ask at Motorworks, Sunrise Highway, Amityville if they'd do it for you. That's all I have! |
05-15-2016, 05:04 AM | #3 | |
Re: sooty oil?
05-15-2016, 10:06 AM | #4 |
Liked 56 Times in 24 Posts
Re: sooty oil?
Did you run a break in oil prior to putting the Amzoil in? Some of them, such as Driven BR will leave traces of dark oil suspension.
05-15-2016, 04:06 PM | #5 |
Re: sooty oil?
05-16-2016, 05:24 AM | #6 | |
Liked 429 Times in 206 Posts
Re: sooty oil?
Do a leak down first. |
05-16-2016, 07:48 AM | #7 | |
Liked 18 Times in 10 Posts
Re: sooty oil?
There are a lot of shops out there that do not believe in plate honing!!!! |
05-16-2016, 07:58 PM | #8 |
Re: sooty oil?
If you read into my first post I said I had a cylinder leaking down. I did the test and found I had a problem. Pulled the head and had gouges in the cylinders causing the leak down. So when I drained the oil I found the sooty stuff in it. I just wanted to confirm it was combustion contamination in the oil. So I torn the motor down and will be pulling it shortly. I am in the process of building a new LS motor so timing was kind of ok in a messed up way.
