Old 05-02-2016, 07:47 AM   #1
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Default
nm
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 05-02-2016, 10:37 AM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: The newest Ford Mustang GT in NHRA Stock Eliminator-Phas
Originally Posted by ALMACK View Post
Not sure if that combo is allowed in Pure Stock Dan. Might be too new.
I know it is legal in the regular FI classes at IHRA.
On that run it was 90 lbs. heavy for I/SA and spun off the line, so had it not spun and was at minimum weight, that may have been a 13.05, just .75 away from the NHRA index and .55 off the E/FIA index @ IHRA.
Stock 3.31 rear gears, stock suspension, stock torque convertor, and totally stock engine. Definitely room for improvement.
For Pure Stock ..call it a 2005..it fits in the Rules.
Since the Engine is similar in all those years.
IHRA maybe compliant and add those years.
I take it you had a roll bar installed correct?
Dan
Old 05-02-2016, 12:12 PM   #3
ALMACK
ALMACK's Avatar
Default
nm
I/PS '95 Mustang GT
Old 05-02-2016, 01:45 PM   #4
goinbroke2
Liked 405 Times in 158 Posts
This is really cool, taking a newer car and doing the "dime rocket" approach as opposed to all the other new cars (mustang/challenger/Camaro) that have massive $$$$ dumped into them.
I hope this works really well for you Alan, good luck. (and chronicle everything with pic's please!)
Old 05-02-2016, 02:26 PM   #5
ALMACK
ALMACK's Avatar
Default
nm
I/PS '95 Mustang GT
Old 05-02-2016, 01:52 PM   #6
Dan Fahey
Dan Fahey's Avatar
[quote=ALMACK;502381]Yes Dan, I had to install a roll bar as per the rules.
This was my very first one I have ever done.
It came out better than I could have imagined.
The seats work as normal and even without swing out bars, the front seats can be removed and re-installed easily.
I did all the fitting of the S&W 8pt. kit and took the car to a welder and he welded it all up.
I had to turn the headrests around because the seat backs now do not lean back as far as stock with the roll bar.
Someday, when I can afford them, I want to buy the adjustable ones.
quote]
AND you kept the back seats...
Just in case someone needs a RIDE ;-)
D
Old 05-02-2016, 02:34 PM   #7
ALMACK
ALMACK's Avatar
Default
nm
I/PS '95 Mustang GT
Old 05-03-2016, 10:33 AM   #8
Dan Fahey
Dan Fahey's Avatar
Can you run VP C10 or C20 or Sunoco 260 GT?
They are all unleaded.
Dan
Old 05-03-2016, 10:52 AM   #9
ALMACK
ALMACK's Avatar
Default
Dan
If I am reading the list correctly, I would say C10 and Sunoco 260 GT are good.
Did you mean 260 GTX ?
Don't see C20 listed:
I/PS '95 Mustang GT
Old 08-21-2017, 12:48 PM   #10
ALMACK
ALMACK's Avatar
Default
nm
I/PS '95 Mustang GT
