Old 04-01-2016, 12:14 AM   #14
davebw31
Default Re: motor home safety
I have been racing since 1962. I retired after 36 years with the State Of Florida as a School Bus Fleet manger. My last seven years I managed the four largest School Bus Fleet in the national. I have been using a Class A motor home towing my 1994 Pace American since 1994. I have had both diesel (2) and gas (2). I sold my 1998 38' diesel Holiday Rambler class A in 2003 when diesel fuel went thru the roof. I bought my current RV, a 2004 National RV Dolphin 36' with the 8.1 chevy fuel injected engine and Allison trans., and 22.5 Michelins. I have towed over 300,000 miles and never blew a front tire, however I have destroyed many, many rears. Here is what I have done in "preventive maintenance and added systems":
I always buy USA tires. Prefer Michelins.
I always run my tires at max rated cold air pressure (dual or single) So screw the ride with lower air pressure. Heat is the death of a tire plus UV rays.
Since my RV and trailer are parked outside I always cover my tires when parked.
I have a Tire Monitoring System, both temp. and air press.
At 3 yrs I buy new fronts, then I rotate my used front tires to the rear, and I usually get another 4 + years of service life. At this time I have my toe checked and set at zero toe with front end on the ground.
I have installed a "Steer Safe System". They do work. I have never lost a steer tire, but I know several racers/RV'ers who have and their coach was badly damaged because they lost control. Also hard braking is a no-no, it just makes it worse.
I have taken a Class A CD driving course and have had a Class A license since 1985 and in 2000 I took a CDL Safety Course.
Most 22.5 tires have a speed rating of only 70 mph. I drive 65 mph, except going down hill getting ready to go up a hill I speed up to 70 mph.
Can it happen to me like it happened to Jeff! Well yes, however I think I have the odds in my favor of it not happening.
Jeff, I know of you and I am very glad you survived. It was not your time to go! Please Jeff install a Steer Safe System. They are not cheap, but next time it may keep you from another catastrophic accident, injury, or your life. Get well soon!
davebw31 is offline   Reply With Quote
