Old 03-29-2016, 12:54 PM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Default Re: motor home safety
Originally Posted by Dick Butler View Post
I was reminded today that the tires on the big motorhomes are originally designed to run 1000's of miles on a semi in a year. None of us uses them that much in the time they can dry rot so they may look fine on the tread and be overlooked. On inspection today found my right front dry rot showing up around the lettering by the rim. For safety I will replace it tomorrow. Plan on getting TYRON installed next month.
Out of interest, how old are the tires you are replacing? My truck tire place says 5 years, regardless of miles on motorhomes. Also can you post how much the tyron costs and the before and after ride quality.....
Thanks
Eric
Eric Merryfield 1883 STK
Old 03-29-2016, 02:12 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,983 Times in 597 Posts
Thanks
Eric
most say 5 years on big truck tires no matter how many miles or tread. I don't think the Tyron system would be a real advantage on a semi type tire. When I blew a steer tire a few weeks ago on my toter there was not enough left of the tire to help with the handling. I was only running 60 - 65 mph when the tire blew so I had no problem keeping control plus I did not have the trailer with me. The tire completely disintegrated when it blew. Sounded like a shotgun when it exploded. I think a TPMS would be the way to go.
Mike Pearson 2485 SS
Old 03-29-2016, 02:16 PM   #3
jmcarter
jmcarter's Avatar
Liked 3,239 Times in 985 Posts
Biggest hazard to tires is heat, and sun if it's parked outside. We're picking up our new MH on Thursday and while the coach is new off the line it will be interesting to see what the date code on the tires reveals. My understanding that Michelins are good for longer than five years provided they're cared for of course. Got TPMS on all my stuff except for the trailer and going to investigate the best way to add it to the trailer, expect I may need some kind of 'booster' at the back of the MH to get the signal forward.
Sure was nice seeing Jeff respond to the thread, obvious his wit survived quite well. When the thread started I was concerned that somebody implied Jeff had somehow done something wrong or neglectful to cause his accident and it was good to see him put it in perspective.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-29-2016, 04:37 PM   #4
Dick Butler
Liked 32 Times in 19 Posts
Interested in the blow out that totally disintegrated the tire. Could it be it was chewed up running on it after it blew? The Tyron keeps the rubber under the rim edge(in theory) while you slow down so the rim does not cut it up going across it. and your rim doesn't get chewed on the pavement. I believe slowing down without braking may be the pearl of the whole discussion. Videos show blow out not even resulting in turning of the vehicle after blow out with tyron but how quickly they applied brakes is not obvious.
I lost a rod at 3/4 track at Indy time trial. Took out left front Moroso tire. Slowed without braking hard and it went straight. Tried to brake it wanted to go to guard rail. Crossed the finish line 114 on blown tire. Tire was not off the rim. Lucky.....
I will post later about dealer for the Tyron close by....
Old 03-29-2016, 06:03 PM   #5
Mike Pearson
There was nothing much left of the tire once I got it stopped. The entire tread was off and hot much left of the sidewalks. I got it stopped quickly and the wheel was not damaged. I was driving through a construction zone so I could have run over something that damaged the tire. It gave no advance notice that anything was going wrong just a loud boom and the front end dropped.
Old 03-29-2016, 09:42 PM   #6
craiger
no,no,no,no implication of any fault. Just trying to make the point that a
$20,000 work beater has multiple air bags and designed crumple zones,
but toter homes and rvs costing many times more don't. I work for a domestic car manufacturer and our car was delayed coming to market by over a year because the crush zones and panels had to be reconfigured.
Should we not expect the same attention to safety in our tow rigs.
P.S. I use Michelins on our mh and change out the 2 oldest tires every year costs me a couple of bucks but is cheap compared to the cost of a blowout.
craiger is offline   Reply With Quote
Old 03-29-2016, 10:38 PM   #7
Dick Butler
Answer: my MH is a 2008 Showhauler on 2008 Freightliner chassis. I have only replaced Left front as there as a crack developing last year. Now replacing Rt front for early weather checking.
It is always garage kept. Only 37,000 miles. All rear tires look fresh. Pressure stable.
Showhauler Motor Homes in Middlebury Indiana is now a dealer for TYRON. Call and ask for Lonnie. He just informed me they are the dealer.. I-574-825-6764. Tell him I mentioned them. They are an outstanding business and build an excellent motorhome.
Thanks
Dick Butler
Old 03-30-2016, 01:52 PM   #8
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
What brand of system do you have? The Doran system that we sell doesn't require a booster but longer rigs need an external antenna under the motorhome towards the back. We sell the additional sensors for $45 each.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
