#1 | |
Liked 18 Times in 10 Posts
I have to ask why a .900 B/C cam and what is the build ? Running reduced base circle cams adds alot of pressure angle which is a killer for lifters. |
#2 | |
Liked 13 Times in 11 Posts
I think clearance wise you may have a little to much if anything. I guess roll the dice those lifters will let you know if they are not happy. What year are your cars ?? |
#4 | |
71 and 65 and thank you. |
#5 | |
They eat up to much cam to rod clearance and cycle time is real short compared to a good steel rod. |
#6 | |
I tend to not do what everyone else does.Thats why I don't bracket race and use a Nash 5 speed. And @3000lbs driver on board 9.30s to 40s nobody ever said I was slow. ![]() |
#7 | |
I would of used an Iron Eagle block rather then compromise cam to rod clearance and have to run a cam that looks like a pencil LOL. Or at least would have gone to a .904 lifter with a .810 wheel to reduce pressure angle. It should be fun to drive !!! Very nice cars though. This article will help explain what you have going on. http://performancetechnician.com/pdf...a-Lifter-2.pdf Last edited by carl hinkson; 03-15-2016 at 07:43 PM. |
