Old 03-09-2016, 08:27 AM   #1
JP Schuster
Default Re: Pro Tree T-Brake Vs. Full Tree T-Brake in SS
Okay thanks guys!
JP Schuster is offline   Reply With Quote
Old 03-09-2016, 04:23 PM   #2
Mike Gray
Mike Gray's Avatar
Liked 704 Times in 203 Posts
Default Also - you can make your own adjustable button
When I raced super-gas I made my own trans brake buttons from surplus snap switches available at a local electronic store for about $2.50 a piece.
This is a similar one that can be ordered for about $9.00. I just made my own shims to change the length of the button travel. I could red light easy when used with little travel.
Old 03-12-2016, 11:07 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Pro Tree brakes are typically fluid exhaust , meaning they rely on line pressure to move the valve when the solenoid releases . .....They are really intended for the Super .90 classes . makes it hard to not go red on a full tree .
They typically us much higher line pressure than a spring actuated valve .
Higher line pressure = more HP consumption = slower ET's !
