If your stall "improvement" was more stall, you should try it before you buy more gear, if you went the other way, I'd say the change sounds reasonable.
Good MPH, that thing is hauling..... ![]() |
Liked 126 Times in 20 Posts
I run the same combo and use a 6:00 rear gear and go thru around 8500. ATI makes a great convertor for that combo Call Cris and tell him you need one just like mine. I also use the short mickey. You might want to switch to radial.
Tim Worner SS 1747 |
What Tim said. He knows the combo.
You have enough tire. The radial is worth about .09-mainly because it wont grow at speed. Stall should be 6000-6200. 6.00 gear is good. Should be 8000-8100 at the traps-higher if you really want to buzz the motor. 2.08 first gear is good. I ran a 1.98. Work out that suspension. Not sure what you currently run for a rear end, but there are great products out there to get it to hook. You shouldn't spin the tire at all-you aren't making any torque. Good luck! Jeff 6990 SS/MA |
Thanks for the input.
I am currently running 5.43 gear with ladder bars and coil overs. Don't realy want to buzz motor over 76-78 but maybe its to late to worry about that. |
Which 250hp combo are you running?
441 heads, I may be off on the 250 horse in years passed thats what it was.
Liked 279 Times in 68 Posts
441 head is from a 69 350-255 which is rated at 294 or 295 in GT.
Greg |
