Old 12-05-2007, 09:48 PM   #1
joker
Default Re: Trans brake 350 turbo
So you don't think getting into high gear before you go wide open will work? I was told to get into high gear before you go wide open.
joker is offline   Reply With Quote
Old 12-06-2007, 12:07 AM   #2
Dennis Paz
Liked 5 Times in 3 Posts
I have 2 cars that run 9.50 in s/st trim and I shift both cars after full power. The only time I wont is if I think the track is junk. I have found the car more consistent this way. What throttle stop are you using? air or electric? I use dedenbear electric with no problem.
Dennis Paz is offline   Reply With Quote
Old 12-08-2007, 01:02 AM   #3
joker
I have air K&R pro cube which is great I also use the pro stage. I will try your numbers it is about where I was last race, first time out with powerglide made it to semi's racing super pro. I used 350 for 2 years it was fine but not good in super street trans brake was to slow. Thanks for your time
Old 12-17-2007, 10:42 PM   #4
Dennis424C
Dennis424C's Avatar
Liked 2 Times in 2 Posts
so is the general opinion here that a TH350 with a brake is not the best way to go for S/ST?
Dennis "The Menace" Clark
424C Pro E/T
424C S/ST H/R S/G
Dennis424C is offline   Reply With Quote
Old 12-19-2007, 12:10 AM   #5
joker
Smile Re: Trans brake 350 turbo
No way to slow oil has to travel to far but I have one i would sell
Old 12-19-2007, 10:31 PM   #6
Dennis424C
Dennis424C's Avatar
well thank you for the info. I guess I won't be buying yours right now. I do thank you for your honest opnion.
424C Pro E/T
424C S/ST H/R S/G
