Liked 13 Times in 8 Posts
It does leak thru the seal.I did talk to a guy who suggested seal conditioner from GM.
Liked 1,825 Times in 414 Posts
Seal conditioner is useless. It just swells the seals temporarily. You can do that with a pint of DOT 3 brake fluid. It will probably do nothing at all. It may just hasten the need for an overhaul.
The lip seals I referred to are inside. Warm the car up to operating temperature, get it to move, then put it in park on a level surface and check the fluid level, make sure that the fluid level is right on the "full hot" mark. Then let the car sit for a day or two. Check the fluid before you start it. Then start the car and immediately check the fluid level. Note the differences.
Alan Roehrich 212A G/S |
#3 | |
Liked 531 Times in 108 Posts
Jim Kaekel 3836 STK |
Replaced the Filter and New Fluid and still is lagging going into gear.Looks like a Rebuild is in order.Thanks Guys for the info..
Liked 239 Times in 114 Posts
Make sure your linkage is adjusted correctly, it needs to be on the drive stop, when the shifter is in drive .
A very common issue with a Turbo 400 or any other automatic with a gear pump is worn gears and crescent. Do not overlook the condition of the pump when doing a freshen up. The pump is designed for the life of the vehicle but when line pressure is increased from a shift kit, manual valve body or trans brake there is much more strain and hydraulic side loading causing wear. The worst case scenario is a street driven vehicle.
