I have pac Springs on my O 41 heads, spring pressures run between 270 and 310. I have lots of room, no shim under the springs. When they were new, spring pressure 350lbs. I have enough room to run a 60 shim and will not coil bind. Would a 60 make much of a difference in pressure. Any suggestions Thanks Jay. GT\DA
Liked 308 Times in 103 Posts
yes that will raise pressure,maybe time for a new set though install them to where they are .060'' from coil bind if they are 1409X will be about 425-450 like that.
Mike Taylor 3601 |
Liked 1,945 Times in 586 Posts
They are the PAC 1.500 double spring that sets up at 2.100. They are pretty old but trying to get a few more runs before a new set.
Mike Pearson 2485 SS |
They are the Pac 1332 spring. Any one know the rate on these springs.
Liked 1,439 Times in 301 Posts
I think everything you need is in the PAC web site
http://www.racingsprings.com/ValveSpringRateCalculator
James Schaechter 3163 STK |
#6 | |
