#41 | |
I don't know about you, but when I race I look at a current rulebook, not a 7 year old rulebook. Racing in 2007 and probably in 2008 you will find under page 55 under stock engine and page 67 under SS engine both say the same thing "crossbreeding of parts prohibited" The B engine mopar and the RB engine mopar are from two families, they share no major components other than cylinder heads. Therefore, it is not neccessary for NHRA to explicitly state the deck height must be OEM. If they did, they would need to provide a tolerance. Also, this RB 383 sited is not listed in the NHRA official blueprint publications so is not an issue to discuss as it is not relevant to the conversation. But thanks for the information. To the prior argument by Bill Dedman that "crossbreeding" denotes taking Ford parts and putting them into a Chevy, that doesn't make sense. At the start of the Stock sectionand SS section as well, there is a section titled Blueprinting which states "stock factory OEM components (unless otherwise specified) must be retained and unaltered (i.e., connecting rods, pushrods, crankshaft, etc.). Good gawd men, I should have made that recital at the beggining of all this mess! With that in mind, why would I have to go around protesting anybody? The rule is so damn explicit it is not even open for interpretation. NHRA, take it from here! |
#42 |
Liked 574 Times in 212 Posts
This entire conversation affects our car. However, it seems that everyone is making a bigger deal out of it than it really is. Their is no difference in using the low deck block than using a decked tall block except the main bearings and distributor. Unless NHRA starts measuring crank CL to the deck (for everyone!!!) Expect to see decked 440 blocks. So, the end result is it will cost us more money to change our engines and add about 20 pounds to the front of the car. I don't understand NHRA's logic, except that it will cost us more money to get the same result in a combination that hasn't run within a tenth of a second of the SS/FA record, set by a Chevy.
#43 |
Rocket...your posts about this subject in my view, have been excellent. You have provided more than enough engine and rule info for anyone to cross-check, should they choose to do so and, regardless of what your real name is.
Regarding stock, it seems like this 'cross-breeding' should be a no-brainer. For super stock, the arguments against this seem equally logically and reasonable. Although racers are always looking for the last bit of performance from their combo, this 'cross-breeding seems to go way beyond the spirit of super stock racing. Maybe for some, the rules explicity don't state this can't be done, buy anyone familiar with regulatory bodies will tell you it's the 'intent' behind the regs that takes precedent over what's written. Agencies often publish this 'intent' in guidance documents. Maybe NHRA should provide this to the tech guys. Sure, super-stock racing has evolved, but do people really want this to go on? Who can make an argument for it? I can point to the 'head rule' as something that got out of hand and now everyone is spending $$$$$$$$$$$$$ because of it. D. Whitmore 3161 Kyle Bros. GT/DA |
#44 | |
![]() David Buckner STK 4772 |
#45 | |
What if you have on the contrary a 3.75 stroke motor like a 440 or a Hemi with a 10.750 deck? This is a terrible disadvantage. It makes your piston like an air compressor. I measured Rick Allison's SS/AA piston about 20 years ago and it weighed over 1000 gms. Of course he didnt have a killer light set, but if you add 1/2 the additional stroke (4.223 - 3.75 = 0.473 then 1/2 = 0.2365 inches), then you add the difference between the Pontiac's 10.200 and the Mopars 10.750......that is another 0.550. So you get a piston that is at least 0.550 plus 0.2365 or 0.7865 shorter. Not only does this take weight out of the piston it takes weight out of the crank to balance. We always used 0.300 compression height as worth a tenth. Maybe with piston technology it isnt that much, but it isnt zero. If you want to read some good info go to Wiseco's website about piston technology and power. It is a good read. http://www.wiseco.com/TechTips.aspx click on "forged piston technology 101" We have been talking to Wiseco about their strutted piston. We can get a compression height of 1 inch with this new strutted piston design with a single ring motor no problem. Pontiac has a block 9.200 deck. With our shorter stroke 9.200's we can get a 3.75 stroked 400 motor pretty killer. Like I said, if NHRA wants to go there we are going to have some weird looking motors out there. Like I said, I have no problem with the BBMopar guys getting it, but we should get it too. 400 Chevy guys would have a killer short block. Rocket block's posts I agree have been excellent! Rocket, you dont know the 1/2 of it, the truth would shock you to the core! Lynn
Lynn A McCarty 3470 SS Last edited by Lynn A McCarty; 12-03-2007 at 02:21 PM. |
#46 | |
Could you just mill a RB family block to obtain the same advantages? Probably. But I don't think there is enough material there and you would probably have a problem with head gaskets and warping the decks. |
#47 | |
The short deck block issue is a serious one, and no one is paying attention. My opinion is that it takes away from the original engine design. If they are going to allow this, then why dont I alter Pontiac heads to fit a 400 Small Block? Lynn
Lynn A McCarty 3470 SS Last edited by Lynn A McCarty; 12-03-2007 at 04:17 PM. |
#48 |
Banned
exept heads so are camshaft,timingchain,rockersystem,oilpump,oilpan,v alvecovers timingcover,etc the same...so different engine familys would be the "grey area" dont you think? hell crossbreeding parts...what about those chevy rods in fords..even stockers..thats crossbreeding to me!also..wonder if they would find any of those 8.200 chevy smallblocks out there if they really start to check this thing?
#49 | |
Liked 1,599 Times in 583 Posts
#50 |
Liked 26 Times in 11 Posts
440 (RB) Deck Height 10.720"
400 (B) Deck Height 9.970" Difference .750" There is no way that you can deck THREE QUARTERS of an inch off of a production Chrysler block. (page 66 "same year and make for car used") The head bolt holes are barely this deep. If this were true, Charlie Maluke (sp.) went through a heck of a lot of trouble to build his short deck Hemi blocks for nothing. Quit lying to yourselves trying to justify what just isn't true. See you at the races, Wayne Kerr |
