Old 01-23-2016, 09:00 AM   #1
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default Pure Stock Roll Bars? other Questions
Regarding a 1986 305 Camaro.
1) Are roll bars allowed in Pure Stock? No mention in rule book not allowed?
2) Aftermarket Shifter allowed?
3) Mini spool in 7.5 rear?
Thanks
Will Lamprecht
Old 01-23-2016, 09:33 AM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Pure Stock Roll Bars? other Questions
Thanks
Will Lamprecht
Roll Bars YES!.
And mandatory if quicker that 11.49sec or Convertible.
Aftermarket Shifter YES.
MiniSpool....I do not know..but should be ok!
They are a bit stronger more reliable than Posi's.
D
Old 01-23-2016, 10:29 AM   #3
impstocker
impstocker's Avatar
Thanks Dan, I knew you would be on this ASAP !!
Have this 1986 Camaro with a great running 305 4 bl , originally thought about 4 cylinder W/SA car (have lots of 151 CI parts for that) but would be cheaper right now to build a PS
Add a higher stall converter for the 700R4 , 4:57 gears w/spool (have) , headers, roll bar (just in case want to make a traditional stocker too one day) fix body ect.
I guess it would fall into E/PS with a 13.40 index. I think very possible with those gears. Even though here in Northeast not much IHRA, car could run ASRA Stock/Super stock combo races, then remove mufflers to bracket race. Also drive on street locally ( would trailer to track)
Will
Old 01-23-2016, 11:03 AM   #4
Lee Valentine
Liked 319 Times in 68 Posts
Will, talk to Lloyd Rielly former owner of RCE Machine in New Milford.He still has his E/PS record holder. He's a great guy and a wealth of knowledge. Call me at The Toy Box and I'll hook you up.
Lee Valentine 1661 STK
Old 01-23-2016, 12:11 PM   #5
Dan Fahey
Dan Fahey's Avatar
Will
Hello Will...very Welcome!
Right now watching the snow come down.
Otherwise yeah should run well under the E/PS index.
Btw if you are using stock exhaust manifolds you can run without mufflers.
Mike Taylor has a similar combo in a Malibu.
Ping Mike Baker confirming the class.
D
Old 01-23-2016, 12:14 PM   #6
Dan Fahey
Dan Fahey's Avatar
Wow...have him send a picture of his car.
D
Old 01-23-2016, 02:15 PM   #7
Lee Valentine
Dan I have a photo of his car on my toolbox at work, I'll get it to you.
Old 01-23-2016, 05:43 PM   #8
Dan Fahey
Dan Fahey's Avatar
Awesome..will post on Pure Stock photo gallery.
Web master only allows 50 pictures and will not let me start a second.
Going to need some help from another racer to post 50 more!
D
Old 01-24-2016, 12:54 AM   #9
THE LEGEND
Will,
Contact CJ McDonald.he has a complete pure Stock rear end for that car.
Chip Johnson
THE LEGEND is offline   Reply With Quote
Old 01-25-2016, 10:59 AM   #10
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 315 Times in 107 Posts
Can run roll bar/cage,but have to keep rear seat though,had mine out and had to reinstall it.
if it is flat top 305 have nice set of venolia pistons .030 they are older so they would be heavy enough to be legal $375.00 for them
Mike Taylor 3601
