Old 12-27-2015, 08:54 PM   #1
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: Porportioning Valve
Just got my new brakes from Lamb. In conversations with Roger he told me a few things.
1. he does not believe in reducing front brake pressure via an adjustable proportioning valve.
2. for 4 wheel discs, 4 piston caliper they recommend a 1 1/8" master cylinder.
I can tell you from my experience building cars, we never use residual pressure valves on cars where the master cylinder is on the firewall. The RPV is only used when the master cylinder is mounted on the floor.
Todd Geisler is offline   Reply With Quote
Old 12-28-2015, 05:15 PM   #2
Tony Goodman
Liked 18 Times in 4 Posts
Thanks for the responses from everyone! I'm going to up grade the M/C to a 1.125 bore, and not use a proportioning valve. Thanks Tony
Tony Goodman is offline   Reply With Quote
