#11 |
Liked 308 Times in 103 Posts
I started using zinc years ago when a customer brought in some he had bought from Mondello,I buy mine half price of what Mondello got for it,have never had any of the zinc disappear ,burn out or erode or whatever you want to call it. I may switch to aluminum, because I always have barrel full of old pistons.
Do you just use plain old cast piston ? Mike Taylor 3601 |
#12 | |
Liked 974 Times in 310 Posts
#13 |
Liked 883 Times in 237 Posts
I've poured dozens of AMC heads over the years.
I melt old cast pistons in a cast iron fry pan over my turkey fryer burner . the pan is small enough to handle the amount of aluminum you will need. You must skim the dross off the top of the aluminum before pouring. As far as prepping the head , the crossover port must be free of carbon to ensure proper filling. I use furnace cement to block the port side for the fill, making sure its in the hole a little ,per the rules. You can get a small tub of the cement at any hardware store ,and its relatively easy to remove when your done . It also helps to warm the head before the pour. ....I usually get them up to 225 deg. before I pour....This helps prevent shrinkage due to the rapid heat transfer to the head.
#14 |
Liked 154 Times in 34 Posts
Is this legal in stock? the way I read it, you can fill the intake manifold port but not the head. Brian 627 stk
#15 | |
Liked 5,129 Times in 1,956 Posts
It's been done for decades.
#16 |
#17 |
The cyl head section in the rule book reads ,"heat riser passage may be blocked from the intake manifold of the cylinder head .
Blocking the passage down in the valve pocket prohibited" As long as the filler is recessed from the pocket ,it's legal. You wont find a spec anywhere ,but I've seen Record holding heads that the filler is recessed about 3/8 of an inch.
#18 | |
Liked 68 Times in 41 Posts
does anybody have that in " notified of approval in writing from NHRA" on how far recessed it must be ? as stated in the section "how to use this RULEBOOK" on page XVII of the 2016 NHRA rulebook just asking as my head guy will not fill them.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
#19 |
Liked 239 Times in 114 Posts
I poured these heads with aluminum yesterday. Interestingly the cast Pontiac pistons I used did not have any metal struts in them. First piece of advice is practice on a head you don't care about first, and the second is make the pour in one shot, trying to add extra aluminum after a short fill may risk having the extra material you pour after, get loose and fall out. I am worried about warping or damaging the head by using a torch to melt the aluminum back out of the passage. Also to prevent aluminum from flowing down the exhaust guide , so I fixed a valve stem into the guide backwards so the tip was flush with the port down in the bowl. That worked out well . I also fabbed up a V -trough to help guide the aluminum past the valve seat. That also worked well. As I said before , Thanks for all the tips. Like anything, the more practice you get the better you get at it !
