Liked 333 Times in 180 Posts
What is either a front ,a rear, or a pair of them worth???--FED 387
Liked 275 Times in 76 Posts
The front usually go for $125 to $150, the rear is not a high demand item like the front. no more than $50 to $75 for it.
As long as they are not bent from an accident you will get the amounts listed plus shipping. I posted information in another thread as the front only weighs 14 lbs compared to the steel version at 31lbs. I do not know what the rear weighs as I do not have one. Sean
Sean Marconette 84 Mustang 5060 SS/N Last edited by Sean Marconette; 12-14-2015 at 09:58 PM. |
Any market at all for them??? Have a friend that has a front & rear --- Rear needs some welding around on 2 of the bolt holes rotted away but an easy fix for anyone that can weld aluminum maybe about 20-30 minutes to repair both holes--FED 387
Liked 19 Times in 12 Posts
Location?
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
Wisconsin
