Old 11-30-2015, 12:06 AM   #21
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: Bypass fuel pressure regulator systems
My current carb is from Bob Book. He is quite picky about carb and fuel system setup.
When I ordered the carb I asked about the regulator bypass setup. He said if you data log fuel pressure you would certainly see an improved fuel pressure reading. He also stated that on track they never saw any positive gains from the bleed system.
His opinion is if you already have it, use it. Otherwise it's not worth the time/money to purchase and install.
Todd Geisler is offline   Reply With Quote
